| Product(s): | SACS |
| Version(s): | 23.00. |
| Area: | Executive |
In SACS V23 how to set the result viewer options in SACS Executive Interactive Programs?
From SACS V23 onwards, the result viewer options are set as precede. Other options are now leaned, and legacy modeler is also scrapped.
Precede will give a better graphical representation and ease of model rotation. Still, if you are looking for post view/interactive fatigue etc, you can run the analysis in V23 and see the output results graphically in any of the older version.
