Product(s): | SACS |
Version(s): | All |
Area: | Dynamic Response |
Community Question:
The Function Generation completes, but both the chart and the plot files are empty.
I have used this info in my seastate file for fatigue case:
LDOPT NF+Z 1.028 7.849 1. 5.GLOBMN
FILE B
CDM
CDM 2.50 0.600 1.200 0.600 1.200
CDM 250.00 0.600 1.200 0.600 1.200
GRPOV
GRPOVAL LEG F
LOAD
LOADCN 1
GNTRF AL 6 0.05 10. 1. 18AIRY
GNTRF AL 6 0.05 4.75 0.25 18AIRY
GNTRF AL 11 0.05 3.40 0.1 18AIRY
GNTRF AL 6 0.05 2.25 0.25 18AIRY
LOADCN 2
GNTRF AL 6 0.05 10. 1. 45. 18AIRY
GNTRF AL 6 0.05 4.75 0.25 45. 18AIRY
GNTRF AL 11 0.05 3.40 0.1 45. 18AIRY
GNTRF AL 6 0.05 2.25 0.25 45. 18AIRY
LOADCN 3
GNTRF AL 6 0.05 10. 1. 90. 18AIRY
GNTRF AL 6 0.05 4.75 0.25 90. 18AIRY
GNTRF AL 11 0.05 3.40 0.1 90. 18AIRY
GNTRF AL 6 0.05 2.25 0.25 90. 18AIRY
END
Any ideas of why I have empty files?
Answer:
During a dynamic Deterministic Wave/ Transfer Function is important to set correctly the water-deep and Mudline Elevation, remember that the water-deep is negative and the Mudline Elevation positive, if you forgue some of these rules and set both values + or -, the charts in the solution will be empty due to the Software can't difference one form the each other.
