| Product(s): | MAXSURF Modeler |
| Version(s): | 23.06.00.137 |
| Area: | Framing |
How to add Frames?
- Make sure that you have set the stations of your model. Go to Data | Design Grid.
- Then turn on the display of sections on the hull, use the Contours command from the Display menu.
- Select one or more sections while holding down the shift key on the Perspective or Body Plan View to add a frame or frames.
- Go to Frames | Add frames, and specify the shape of the frames.
Please see the Maxsurf Modeler Manual page 252 (Adding a Frame) for more information.
