| Product(s): | MAXSURF Multiframe |
| Version(s): | 23.07.00.268 |
| Area: | Plot View |
The legend, when viewing the results on deflection, cannot be adjusted and will automatically stay in the maximum value. How to change it in every load case?
The legend range of value is the same for all the load cases.
It does not change every load case since it will let users check which of the load case has the max value for visualization purposes.
For example, clicking Davits Out up to CLC1 we can compare directly which joint has the maximum deflection with the use of the visual representation.
However we can always check the displacement values on the Result Window and verify the max values for each load case. I hope this makes sense.
