04. AutoPIPE command - Rotate
FAQ about AutoPIPE Rotate command
  1. What is the procedure to rotate all or a potion of an AutoPIPE model?
  2. What, if any, are known issues or limitations with rotating piping?
  3. What changes where added in the Rotate command in version 09.06 and higher?
  4. What axis should the pipe be rotated about: X-axis, Y-axis, or Z-axis when using Rotate command?
  5. How to print the "Component Rotation"report?
  6. Right click Pan-Zoom-Rotate command does not function correctly
Cut / Copy / Paste / Rotate / Move / Stretch Commands
