| Product(s): | Sacs |
| Version(s): | ALL. |
| Area: | Seastate |
Community Question:
How to know which Wind units are compatible with my model SACS?
Comments
Depending on the units in the card LDOP in your SACS model you will have the option to work with different units like m/seg, mph, ft/s, or knots, but the selection of the units is related to the units of the global model, below we have some recommendation for chose the correct unit for your model.
On another hand, when you have the model in EN units (LDOPT card), you have the possibility to select between units' miles per hour, ft/sec, and knots, All are supported for sacs, and all options will report the forces in KIPS
