DNV C204 Edition for Ship Indentation Curve in Collapse Advance Module
Product(s):SACS
Version(s):23.00.
Area:Collapse
Please confirm if SACS is referring the DNV C204-2010 edition instead of the latest revision for using ship indentation curve?
The curves featured in Collapse Advanced are taken from DNV C204 - 2010 Edition. However, one can input the new curves from DNV C204 - 2021 Edition using the user-defined ship indentation. By adding multiple SHPIND lines, one can input their desired curve based on the 2021 edition and indicate the name of the user-defined curve on the IMPACT line.
