Combined Plate Stress calculation in SACS:
To illustrate the calculation method, let us take a sample SACS Plate Stress Result data as below
For conventions of Membrane & Bending stresses in Plate element, refer SACS POST manual.
Computations of principal stresses are given by the following equations.
The maximum stress combinations used in SACS program is given as below (see SACS POST Manual)
To evaluate the plate combined stresses here, 2 sets of data is considered which are obtained from a sample SACS analysis. The first line of the represents Data 1 and the second line represents Data2 respectively of the above SACS output.
Check for Data1:
Sx = 0.81 N/mm2
Sy = 9.28 N/mm2
Txy = 6.4 N/mm2
SP1 = (0.81+9.28)/2 + Ѵ ((0.81-9.28)2/4 + 6.42) = 12.72 N/mm2
SP2 = (0.81+9.28)/2 – Ѵ ((0.81-9.28)2/4 + 6.42) = -2.63 N/mm2
Hence, SP (Maximum Combined SP in SACS output) = 12.72 N/mm2
Check for Data2:
Sx = -0.81 N/mm2
Sy = -9.28 N/mm2
Txy = -6.4 N/mm2
SP1 = (-0.81-9.28)/2 + Ѵ ((-0.81+9.28)2)/4 + -6.42) = 2.63 N/mm2
SP2 = (-0.81-9.28)/2 – Ѵ ((-0.81+9.28)2)/4 + -6.42) = -12.72 N/mm2
Hence, SP (Maximum Combined SP in SACS output) = -12.72 N/mm2
Check for Data1:
Sx = -1. 98 N/mm2
Sy = -7.4 N/mm2
Txy = -2.08 N/mm2
SP1 = (-1.98-7.4)/2 + Ѵ ((-1.98+7.4)2)/4 + -2.082) = -1.23 N/mm2
SP2 = (-1.98-7.4)/2 – Ѵ ((-1.98+7.4)2)/4 + -2.082) = -8.11 N/mm2
Hence, SP (Maximum Combined SP in SACS output) = -8.11 N/mm2
Check for Data2:
Sx = 1. 98 N/mm2
Sy = 7.4 N/mm2
Txy = 2.08 N/mm2
SP1 = (1.98+7.4)/2 + Ѵ ((1.98-7.4)2)/4 + 2.082) = 8.11 N/mm2
SP2 = (1.98+7.4)/2 - Ѵ ((1.98-7.4)2)/4 + 2.082) = 1.23 N/mm2
Hence, SP (Maximum Combined SP in SACS output) = 8.11 N/mm2
Check for Data1:
Sx membrane = 0.81 N/mm2; Sx bending = -1.98 N/mm2
Sy membrane = 9.28 N/mm2; Sy bending = -7.4 N/mm2
Txy membrane = 6.4 N/mm2; Txy bending = -2.08 N/mm2
Case1:
Sx1 = Sx membrane + Sx Bending = 0.81-1.98 = -1.17 N/mm2
Sy1 = Sy membrane + Sy bending = 9.28-7.4 = 1.88 N/mm2
Txy1 = Txy membrane + Txy bending = 6.4-2.08 = 4.32 N/mm2
SP1_case1 = 4.94 N/mm2 (by Equation 1)
SP2_case1 = -4.23 N/mm2 (by Equation 2)
Tmax_case1 = (4.94+4.23)/2 = 4.58 N/mm2 (by Equation 2)
Case2:
Sx2 = Sx membrane - Sx Bending = 0.81+1.98 = 2.79 N/mm2
Sy2 = Sy membrane - Sy bending = 9.28+7.4 = 16.68 N/mm2
Txy2 = Txy membrane - Txy bending = 6.4+2.08 = 8.48 N/mm2
SP1_case2 = 20.7 N/mm2 (by Equation 1)
SP2_case2 = -1.23 N/mm2 (by Equation 2)
Tmax_case2 = (20.7+1.23)/2 = 10.96 N/mm2 (by Equation 2)
Hence, maximum combined principal stress SP, reported in SACS output = 20.7 N/mm2
and Tmax reported in SACS output = 10.96 N/mm2
Check for Data2:
Sx membrane = -0.81 N/mm2; Sx bending = 1.98 N/mm2
Sy membrane = -9.28 N/mm2; Sy bending = 7.4 N/mm2
Txy membrane = -6.4 N/mm2; Txy bending = 2.08 N/mm2
Case1:
Sx1 = Sx membrane + Sx Bending = -0.81+1.98 = 1.17 N/mm2
Sy1 = Sy membrane + Sy bending = -9.28+7.4 = -1.88 N/mm2
Txy1 = Txy membrane + Txy bending = -6.4+2.08 = -4.32 N/mm2
SP1_case1 = 4.23 N/mm2 (by Equation 1)
SP2_case1 = -4.94 N/mm2 (by Equation 2)
Tmax_case1 = (4.23+4.94)/2 = 4.58 N/mm2 (by Equation 2)
Case2:
Sx2 = Sx membrane - Sx Bending = -0.81-1.98 = -2.79 N/mm2
Sy2 = Sy membrane - Sy bending = -9.28-7.4 = -16.68 N/mm2
Txy2 = Txy membrane - Txy bending = -6.4-2.08 = -8.48 N/mm2
SP1_case2 = 1.23 N/mm2 (by Equation 1)
SP2_case2 = -20.7 N/mm2 (by Equation 2)
Tmax_case2 = (1.23+20.7)/2 = 10.96 N/mm2 (by Equation 2)
Hence, maximum combined principal stress SP, reported in SACS output = -20.7 N/mm2
The snap below provides the summary of the calculations.
Check for Data1:
SP1_case1 = 4.94 N/mm2 (See Section 3 of this Calculation Note)
SP2_case1 = -4.23 N/mm2 (See Section 3 of this Calculation Note)
SP1_case2 = 20.7 N/mm2 (See Section 3 of this Calculation Note)
SP2_case2 = -1.23 N/mm2 (See Section 3 of this Calculation Note)
Hence, von Mises stress is given by equation 4 as
VM_case1 = [4.94^2 + -4.23^2 – (4.94*-4.23)]^0.5 = 7.94 N/mm2
VM_case2 = [20.7^2 + -1.23^2 – (20.7*-1.23)]^0.5 = 21.33 N/mm2
Hence, maximum von Mises stress reported in SACS output = 21.33 N/mm2
Check for Data2:
SP1_case1 = 4.23 N/mm2 (See Section 3 of this Calculation Note)
SP2_case1 = -4.94 N/mm2 (See Section 3 of this Calculation Note)
SP1_case2 = 1.23 N/mm2 (See Section 3 of this Calculation Note)
SP2_case2 = -20.7 N/mm2 (See Section 3 of this Calculation Note)
VM_case1 = [4.23^2 + -4.94^2 – (4.23*-4.94)]^0.5 = 7.94 N/mm2
VM_case2 = [1.23^2 + -20.7^2 – (1.23*-20.7)]^0.5 = 21.33 N/mm2
