After running a static analysis (with PSI, Sacs & Seastate input files), at the moment to open the postvue database appears the following input error:
This issue pass as a result in the configuration of the run file, to avoid this error you have to change the option
Graphical Post Processing Option - Use OCI file as model input, set as "NOT" use oci
