How to generate a Quick Log
Process
From any grid within OpenGround, highlight the Borehole you wish to create, right click on the Borehole and select 'Quick Log'
From the toolbar you can change the 'Template', 'Paper Size', 'Scale' and 'Orientation' of the Quick Log.
The Quick Log can then be saved as a PDF if desired.
