Applies To | |||
Product(s): | MicroStation | ||
Version(s): | 08.11.09.459 | ||
Environment: | Windows 7 32 bit,Windows 7 64 bit | ||
Area: | Cells | ||
Subarea: | General | ||
Original Author: | Reginald Wallace, Bentley Technical Support Group | ||
How can you change mirror settings for placing cell through keyin?
Product: MicroStation V8i/MicroStation V8 XM Edition
Version: 08.11.05.17
Area: Cells, Problem ID#: 37041, DEFINEDSTEPS
Use the "Set Item" key-in to change items in the tool settings dialog.
To do this:
1. Start place cell tool (i.e. Place Cell Icon)
2. Utilities > Key-in and then enter "Set Item Toolsettings "
Expand the keyin browser , you will see a set of named variables for the
active tool... you can set/toggle those "settings" by adding "=value".
For example
you can toggle on and off the mirror setting or you can toggle which
mirror setting you want to use, horizontal, vertical or both.
set item toolsettings cellmirrortoggle=0 (mirror toggle off)
set item toolsettings cellmirrortoggle=1 (mirror toggle on)
set item toolsettings cellmirrortype=0 (for horizontal)
set item toolsettings cellmirrortype=1 (for vertical)
set item toolsettings cellmirrortype=2 (for both)
http://communities.bentley.com/communities/other_communities/askinga/w/askinga/cells.aspx
