Did you know that you can actually change the orientation of a reference attachment, simply by clicking in the orientation column of that reference in the reference dialog?
______________________________________________________________________________________________
Change Reference View - In this edition you can change the orientation of the reference attachment by clicking the reference's Orientation column in the References dialog.
Ref Dialog, Orientation, change views
