Applies To | |||
Product(s): | MicroStation | ||
Version(s): | 08.05.02.35 | ||
Environment: | N\A | ||
Area: | Interchange | ||
Subarea: | IFC | ||
Original Author: | Bentley Technical Support Group | ||
IFC file doesn't import : IFC file does not import into V8.5
File was exported from software called Logocad Triga.
Version: 08.05.02.35
Product: MicroStation V8 2004 Edition
Area: Interchange
The SAT file was created using ACIS version 14.0.
MicroStation 08.05.02.x uses ACIS version 13.0,
therefore it cannot read the SAT file which is based
on a newer version of ACIS.
MicroStation XM uses ACIS 15.06, so if you import
the SAT file in XM it is successfully imported.
