How to edit and create Data Entry Profiles
Explanation
The Data Entry Tool includes 5 default profiles which are based on a location type, these are basic profiles so if you find they dont include fields and/or the tables you're expecting then you can edit the default profiles or even create your own from within OpenGround. If you wish to do this please work through the steps below;
Process
If all went well, you should now have your new step with its new grid and columns.
