Applies To | |||
Product(s): | MicroStation | ||
Version(s): | 08.09.02.28 | ||
Environment: | N\A | ||
Area: | Configuration | ||
Subarea: | General | ||
Original Author: | Bentley Technical Support Group | ||
Default size for defining Configuration Variables.
Default Size: 51 KB
To increase the Maximum size for loading a Config file the following
variable needs be defined & a value in Kb needs to be set.
MS_MAXCFGVARS= <Value>
