Applies To | |||
Product(s): | MicroStation | ||
Version(s): | 08.05.01.25 | ||
Environment: | N\A | ||
Area: | Custom Linestyles | ||
Subarea: | N\A | ||
Original Author: | Bentley Technical Support Group | ||
How to create a Custom LineStyle to react the same way AutoCad displays its lines with Line Segments & Dashes. By setting up this custom linestyle the line segment will always start with a line & end with a line. The second technique stretches / shrinks the gaps slightly to make things fit. The first technique just expands / contracts the end segments but does not look as nice as the first option.
Product: MicroStation V8 2004 Edition
Version: 08.05.01.25
Area: Custom Linestyles
1. To make a line style display in the way that AutoCad controls them:
Element>Line Style>Edit
File> Open select the line style resource they want
Select the stroke style that they are interested in
In the Stroke Pattern Attributes section, Toggle "Single segment" & Select "Shift: center"
2. This method will give you a better line style, but not exactly what
AutoCAD uses:
File> open select the line style resource they want
Select the stroke style that t hey are interested in
In the Stroke Pattern Attributes section, Toggle "Single segment" & Select "Shift: Fraction" & setting the fraction to 0.5
Then allow one or preferably all of the gaps to be variable:
Click on one of the gaps in Stroke Pattern
Set "Length> Variable"
Click on next gap
