Applies To | |||
Product(s): | MicroStation | ||
Version(s): | 07.01.04.10 | ||
Environment: | N\A | ||
Area: | Custom Linestyles | ||
Subarea: | N\A | ||
Original Author: | Bentley Technical Support Group | ||
How to set custom linestyle scale and width using key-in.
First Key-in:
MDL LOAD CALCULAT
To enable ORIGIN WIDTH:
Key-in: CALC tcb->lineStyle.modifiers=10
To enable END WIDTH:
Key-in: CALC tcb->lineStyle.modifiers=18
To enable both ORIGIN WIDTH and END WIDTH:
Key-in: CALC tcb->lineStyle.modifiers=26
To Disable both ORIGIN WIDTH and END WIDTH:
To set ORIGIN WIDTH VALUE:
Key-in: CALC tcb->lineStyle.startWidth=(desired value)
To set END WIDTH VALUE:
Key-in: CALC tcb->lineStyle.endWidth=(desired value)
To set SCALE VALUE:
Key-in: CALC tcb->lineStyle.scale=(desired value)
To enable SCALE:
Key-in: CALC tcb-> lineStyle.modifiers|=1
To disable SCALE:
Key-in: CALC tcb->lineStyle.modifiers|=~1
To set SHIFT to NONE:
To set SHIFT to DISTANCE:
CALC tcb->lineStyle.modifiers=58
To set SHIFT to FRACTION:
CALC tcb->lineStyle.modifiers=90
CALC tcb->lineStyle.modifiers=154
To set SHIFT VAL UE:
CALC tcb->lineStyle.shift=(desired value)
Note:
Values may not reflect the change in dialog, if Custom LineStyle dialog
is open.
