Document Type: TechNote
Product(s): MicroStation
Version(s): V8 2004 Edition
Legacy Document Number: 8502
This document contains a list of the MicroStation Element numbers and element types.
Element Number | Element Type |
1 | Cell Library Header |
2 | Cell Complex Header |
3 | Line |
4 | Line String |
5 | Group Data |
6 | Shape |
7 | Text Node Header |
8 | Digitizer Setup Data |
9 | Design File Header |
10 | Level Symbology |
11 | Curve |
12 | Complex Chain Header |
13 | Conic |
14 | Complex Shape Header |
15 | Ellipse |
16 | Arc |
17 | Text |
18 | 3D Surface Header |
19 | 3D Solid Header |
20 | Subfigure |
21 | B-Spline Pole |
22 | Point String |
23 | 3D Circular Truncated Cone |
24 | 3D B-Spline Surface Header |
25 | 3D B-Spline Surface Boundary |
26 | B-Spline Knot |
27 | B-Spline Curve Header |
28 | B-Spline Weight Factor |
29-32 | Reserved |
33 | Dimension |
34 | Shared Cell Definition |
35 | Shared Cell Instance |
36 | Multi-Line |
37 | Tag Data |
38 | Smart Geometry |
39-50 | Reserved |
51 | ARCH |
54 | SDS |
56 | IEDS, WMS |
57 | ICS, SDI (stereo plotter parameters) |
58 | Text ARRAY |
59 | Text STACK |
60 | SIS |
61 | EWS SCHEMATIC |
62 | EWS PANEL |
63 | EWS, PDS |
64 | Application Element |
65 | Application Element |
66 | MicroStation Application Elements |
67-86 | Application Element |
87 | Raster Header (imported) |
88 | Raster Data |
89 | Application Element |
90 | Binary Raster Header (referenced) |
91 | Raster Reference Component |
92 | Raster Hierarchy Element |
93 | Raster Hierarchy Component |
94 | Reserved for raster data |
95 | Table Entry Element |
96 | Table Header Element |
97 | View Group Element |
98 | View Element |
99 | Level Mask Element |
100 | Reference Attach Element |
101 | Matrix Header |
102 | Matrix Int Data |
103 | Matrix Double Data |
105 | Mesh Header |
108 | Reference Override Element |
110 | Named Group Header |
111 | Named Group Component |
112-125 | Application Element |
126 | User Defined |
127 | Reserved |
Note: 91-125 were initially "blocked" off for third party apps etc.. for any element types that they created for their own apps. Over time, MicroStation has dipped into those element types for its additional element types such as Named Groups etc...
This information can also be obtained from the mselems.h file which is located in the \bentley\program\MicroStation\mdl\include directory. This document however does not contain the entire list of element types.
MicroStation Desktop TechNotes and FAQs
