Applies To | |||
Product(s): | MicroStation | ||
Version(s): | V8 2004 Edition (v08.05.02.15 and below) | ||
Environment: | N/A | ||
Area: | N/A | ||
Subarea: | N/A | ||
Original Author: | Bentley Technical Support Group | ||
This document is provided to address a known MicroStation MSXML installation issue.
When installing MicroStation V8 under an administrative account on a Windows NT or Windows 2000 based computer, users other than the administrator on that machine will receive errors that MSXML is not properly registered.
This issue has been resolved in the MicroStation 08.05.02.27 commercial release installer. If you have a need to patch this issue on versions prior to the MicroStation 08.05.02.27 commercial release as a administrator or power user you can administer any of the following options illustrated with the "silent install" steps required:
Note: Before making changes to your machine be sure to check with your systems administrator.
