Applies To | |
Product(s): | AutoPIPE |
Version(s): | ALL; |
Area: | |
Date Logged & Current Version | June 2019 12.01.00.10 |
E516-8: Demo version limit of 20 points exceeded... message appears in AutoPIPE, why?
Error
OK
As seen in AutoPIPE help:
If no valid license is available then AutoPIPE will run in a limited function Demo mode.
AutoPIPE
- Cannot insert more than 20 points in the model.
- Cannot run any analyses if the model has more than 20 points.
Note: In Demo mode any file can be imported into AutoPIPE but a valid license is required to export or Save as a model to Caesar II Neutral (*.cii) file.
Configure license as mentioned on WIKI here.
If more information is needed or require 1 on 1 steps in configuring, submit an Service Request mentioning this web page
