Applies To | |||
Product(s): | AutoPIPE, | ||
Version(s): | 2004, XM, & V8i | ||
Area: | Error | ||
Original Author: | Bentley Technical Support Group |
The following is being displayed:
"A problem caused the program to stop working correctly. Please close the program."
How to resolve the issue?
1. Start AutoPIPE, open a model, run a complete analysis on the model, create a model input listing report with Tools> Model Input Listing> enable all sub reports, press OK button, in a moment AutoPIPE Report Viewer should display the report. Do you see this report?
2. Also, select Results> Output report> enable all sub reports, press OK button, in a moment AutoPIPE Report Viewer should display the report. Do you see the report?
3. Using Windows Explorer, navigate to the following file:
a. Folder location where your model is stored, can you find the following files in the same folder:
i. systemname.OUT
ii. systemname.RPT
c. C:\ Bentley\ AutoPIPE V8i SELECTseries\ apipview.exe
Question: double click on the file to start it. Does AutoPIPE Report Viewer application start and do you see a blank screen?
Please file a service request.with answers to these questions.
Workaround: Open the *.OUT & *.RPT files using any text editor (i.e. UltraEdit, NotePad++, MS Word, etc..)
