| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Export |
| Date Logged & Current Version | April. 2018 11.03.00.08 |
IF STAAD is Not installed on the computer, can AutoPIPE still export a file using PipeLink?
Yes, export to STAADD using PipeLink is a command in AutoPIPE. See below.
Again, STAAD does not need to be installed to create a PipeLink file from AutoPIPE
Export Model to STAAD Using PipeLink (*.pipelink)
