01b. What does the [TR] mean in AutoPIPE's code compliance report?
Product(s):AutoPIPE
Version(s):All
Area: Reports
Date Logged
& Current Version
Jan 2015
09.06.01.10
Problem:
What does the [TR] mean in the code compliance report below:
     ASME B31.3 (2006) CODE COMPLIANCE
           (Moments in ft-lb , Force in lbf
Point  Load                   Axial
name   combination            Force
A04 N+ Max P
       GR + Max P             17003
       TR:T2 to T3             2768
       Amb to T1               1383
       Amb to T2                367
       Amb to T3               2401
       T1 to T2                1750
       T1 to T3                1018
       T2 to T3                2768
What does TR: T2 to T3?
 The TR is the In short, see AutoPIPE Tools> Model Options> Results> Intermediate stress points, refer to the online help fro details.
In the Code Compliance report, the Max Range combination is printed as "TR:"" followed by the thermal range that produces the maximum stress, e.g. "TR:T1-T3", where "TR:" is the abbreviation for (T)hermal (R)ange. Using the Max Range option provides the maximum stress range without printing the results for every thermal range combination explicitly.
The setting is controlled by Tools>Model Options> "Include Max Range comb". See the online help for full details on this setting. In addition, review the Tools> Model Options> "No. of thermal ranges" settings, again see the online help for details on this setting.
"Code Compliance" sub-report using Results> Output Report
