Applies To | |||
Product(s): | AutoPIPE, | ||
Version(s): | ALL | ||
Environment: | N/A | ||
Area: | Load | ||
Original Author: | Bentley Technical Support Group | ||
How can the pipe movement be greater than the support gap setting for wind load combinations in AutoPIPE?
Please see the following file "Nonlinear_wind_load_analysis.pdf". It all depends on the specified load sequence or initial state. Defining nonlinear wind loads is much easier in AutoPIPE as all combinations are created for you automatically.
