Applies To | |
Product(s): | AutoPIPE |
Version(s): | ALL; |
Environment: | N/A |
Area: | Wave Load case |
Original Author: | Bentley Technical Support Group |
Date Logged & Current Version | March. 2017 11.00.00.22 |
Is there another way to define current lift coefficient other than using "Insert> Xtra Data> Hydrodynamic data"?
The Lift coefficient for all points is assumed zero unless identified by Insert> Xtra Data>Hydrodynamic Data.
