Applies To | |||
Product(s): | AutoPIPE, | ||
Version(s): | All | ||
Environment: | N/A | ||
Area: | Analysis | ||
Original Author: | Bentley Technical Support Group | ||
Sept 2013, AutoPIPE V8i 09.06.00.15
How to apply the Hydrotest load and analyze it in the new version of AutoPIPE V8i 09.06.01.10?
Please see the following file installed with:
Help > Contents> Contents Tab> Bentley AutoPIPE> Supplemental Documentation> Hydrotest Tutorial
C:\Bentley \AutoPIPE V8i SELECTseries \Documents \ Hydrotest Tutorial_rev_6.pdf
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
