Civil Tool
Profile - The profile tool allows users to view the profile of an alignment or other linear geometry. After the selecting the tool, the user needs to select the alignment or linear geometry they want to view. After selection, a 2nd viewport will open which displays the vertical curve information of the selected element. Within the 2nd viewport the user can see Stations, Slopes, K/R Values, Intersect and Tangent points and more. When your cursor is in the profile view the elevation and station will also be displayed along with a match line in the plan view to show where you are in both profile and plan.
Note: In order to have this level of detail in the profile view the design must be loaded from OpenRoads Designer. Loading from an older Civil product or through an i.dgn file will not include the alignment.
On the left side of the profile view the profile button will show if there are additional profile associated with the alignment you selected.  Those can be turn on or off.
