Applies To | |||
Product(s): | InRoads | ||
Version(s): | 08.11.07.615 | ||
Environment: | N/A | ||
Area: | Surface | ||
Subarea: | |||
Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
When using the Delete Triangle command, why do the triangles not disappear from the DGN after they are deleted?
A possible reason for this problem is that when the triangles were originally written to graphics the Pencil/Pen Lock was set to "Pen". To correct, ensure that the lock is set to "Pencil", delete all triangles from graphics using microstation delete, and redisplay them.
