Applies To | |||
Product(s): | InRoads | ||
Version(s): | 08.11.07.615 | ||
Environment: | N/A | ||
Area: | Roadway Designer | ||
Subarea: | |||
Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
Question:
How do I generate a report or listing for several of the Roadway Designer screens such as template drops, point controls, template views, etc?
Solution: Within Roadway Designer, select Tools>Results Report, Select your desired Corridor and points to
Report At. Within Bentley Civil Report Brower, Select the Roadway Design Leaf, you have a few options as to your report format but you may want to start with RaodwaySetup.xsl.
