Applies To | |||
Product(s): | InRoads | ||
Version(s): | 08.11.07.615 | ||
Environment: | N/A | ||
Area: | Survey | ||
Subarea: | |||
Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
Why am I inable to select any planimetrics in the graphics file?
Most likely the graphics are only "dynamic graphics". Dynamic graphics refers to the ability of InRoads Survey to display and update temporary graphics – graphics that are not stored in the CAD file. To write the graphics to the design file, run the command Survey>View Survey Data>Write Survey Data to Graphics.
