Steps for Uninstalling Bentley MX from the machine
 Product(s):Bentley MXRoad
 Version(s):All
 Environment: N/A
 Area: N/A
 Subarea: N/A
This functionality will help all in Uninstalling the MX Software from the Machines.
Steps Uninstalling Bentley MX from the Machine:
    1. Uninstall Bentley MX V8i 08.11.xx.xx from Add/Remove Programs
    2. Uninstall Bentley MX V8 XM Edition from Add/Remove Programs
    3. Uninstall Bentley MX CAD Engine from Add/Remove Programs
    4. Delete any remaining files/folders and registry entries as outlined below:
Check these areas after uninstall of MX XM and MX Cad engine from Add/Remove programs when no other Bentley applications are installed. Most will already be deleted but some are left behind by design:
C:\Program Files\Bentley\MX or similar
C:\Program Files\Bentley\MX CAD Engine or similar
C:\Windows\Moss folder
C:\Windows\moss* files
C:\Windows\mfm* files
C:\Windows\mfa* files
C:\Program Files\Common Files\Bentley Shared
C:\Program Files\Bentley\Program\Licensing
C:\Documents and Settings\All Users\Application Data\Bentley
C:\Documents and Settings\<UserName>\Application Data\Bentley
C:\Documents and Settings\<UserName>\Local Settings\Application Data\Bentley
In the registry:
HKLM\Software\Infrasoft
HKLM\Software\Bentley (Ensure you retain any licence activation details from
HKEY_LOCAL_MACHINE\SOFTWARE\Bentley\Licensing\1.1 if required).
HKLM\Sofware\Bentley Systems, Incorporated
HKCU\Software\Infrasoft
HKCU\Software\Bentley
HKCU\Sosftware\MOSS for Windows
If these exist they can all be deleted before installing MX V8i.
  1. Install latest Bentley MX V8i (08.11.xx.xx)
Product TechNotes and FAQs
MX TechNotes And FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
