| Product(s): | InRoads | ||
| Area: | Geometry | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
How do you change the direction of an alignment?
Use the Transpose Alignment command in Geometry > Utilities > Transpose.
This command reverses all data within the selected horizontal alignment. The first element becomes the last element, and so forth. Left-hand arcs (either circles or spirals) become right-hand arcs, and right-hand arcs become left-hand arcs.
