| Product(s): | Bentley MXROAD | ||
| Version(s): | N/A | ||
| Area: | Modify | ||
| Subarea: | Edit Strings | ||
| Original Author: | Jason Walsh, Bentley Technical Support Group | ||
How to creating a string with Regular Chainage Intervals from an Existing String.
Load the Convert to 6D Master String tool (MX>Modify>Edit Strings>Convert to 6D Master String).
To create a new string with Regular Chainage intervals you have to ensure to select the option for At Regular Chainage Points Only as highlighted above.
Linemode Minor Option 027 is the option for Convert to 6D Master String. The linemode options for that option are detailed below.
This is an example of how to use Minor Option 027.
EDIT,PGM
027,M001,2=REGU,3=MC99,4=0.,7=10.,10.1
999
