| Product(s): | InRoads | ||
| Area: | Installation | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
Can I install both the SS2 and SS3 versions of Microstation and have InRoads Suite load in both MicroStation versions?
No. This configuration is not supported by InRoads. To propertly install InRoads, please make sure that you have only one MicroStation version installed.
