| Product(s): | InRoads, Power Civil for [Country] | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Kevin McDonald, Bentley Technical Support Group | ||
The following error message occurs duing install of InRoads or PowerCivil for [Country]:
Fault in the command line of this page
row:
1078
mark : 1
fault:
InstallerGUI_startinstallation not defined
code:
0
URL:
file:///C:/Users/{user.name}ppData/Local/Temp/IXP000.TMP/_en_ProductInstallerGUI.hta
Will you execute commands on this page ?
This error is most likely caused by a virus scanning software that has changed the path of registry key used by Windows Installer. To fix the problem, follow these steps:
(If a virus scanning software has modified this key, you may see paths such as "C:\Program Files (x86)\Common
Files\McAfee\SystemCore\ScriptSn.20120222222556.dll" instead of the Windows default path of "C:\Windows\SysWow64\VBScript.dll".)
