Applies To | |||
Product(s): | InRoads | ||
Version(s): | 08.11.07.615 | ||
Environment: | N/A | ||
Area: | Roadway Designer | ||
Subarea: | |||
Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
Why can't I access the Overlay Tools in Roadway Designer?
The Overlay Tools are only available when the Roadway Designer Display Mode is set to Overlay. The Display Mode is in the bottom right-hand corner of the Roadway Designer dialog.
