| Product(s): | InRoads | ||
| Area: | Cross Sections | ||
| Subarea: | |||
| Original Author: | Chris Key, Bentley Technical Support Group | ||
Under the Evaluation tools in InRoads V8i SELECTseries2, the Cross Section option is missing.
The Cross Section command is not available in some of the InRoads products. The Cross Section commands are NOT available in InRoads Bridge, Storm & Sanitary, Survey, or PowerSurvey. Therefore if you are in one of these products you will not have the ability to create cross sections.
