| Product(s): | InRoads | ||
| Area: | Drafting | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
In running the Plan and Profile Generator command how can sheet be produced that consist of two rows of plan only?
This can be done by selecting the Layout in Grid option on the Sheet Layout tab, the user can then enter the Number of views (2) on the View Layout tab and this will produce sheets that consist of two rows of plan only.
