| Product(s): | InRoads | ||
| Version(s): | 08.11.07.566+ | ||
| Area: | Geometry | ||
| Subarea: | |||
While running the Geometry>Utilities>Multicenter Curve command, the user gets the error message "Duplicate Alignment Name" when prompted to "Identify Second Alilgnment".
This message can be issued when there is only one horizontal alignment in the current project. The Multicenter Curve command requires that both alignment 1 and alignment 2 be in the same geometry project.
