| Product(s): | InRoads | ||
| Area: | Roadway Designer | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
After, creating components in my template library, I would like to add them as end condition exceptions to a station range in roadway modeler, but only one template appears when I look to add a different template I created. I am not sure why the folder does not have the same templates available in roadway modeler as it does in the template library.
This issue of not seeing all of the templates created when the End Condition Exceptions command is valid. The End Condition Exceptions command only displays End Conditions, is does not display templates.
