After entering credentials, CONNECTION Client displays an animation as it attempts to sign in, but it never completes.
A duplicate entry in a Microsoft .NET Framework configuration file on the computer may be causing the problem. To check for this, perform the following steps:
Below is an example found in the BeLicSvc.log file:
Exception Information Details:
Exception Type: System.Configuration.ConfigurationErrorsException
Message: An error occurred creating the configuration section handler for system.data: Column 'InvariantName' is constrained to be unique. Value 'Pervasive.Data.SqlClient' is already present. (C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Config\machine.config line 152)
The first highlighted selection shows the error that was searched. The second highlighted selection shows the value that has a duplicate entry. The third highlighted selection shows the configuration file and specific location where further investigation is required.
Below is an example from a machine.config file manifesting this issue:
<system.data>
<DbProviderFactories>
<add description="Pervasive Provider, Current Release 4.2" invariant="Pervasive.Data.SqlClient" name="Pervasive PSQL Provider" type="Pervasive.Data.SqlClient.PsqlFactory, Pervasive.Data.SqlClient, Version=4.2.0.0, Culture=neutral, PublicKeyToken=c84cd5c63851e072"></add>
<add description="Pervasive Provider, Release 4.0" invariant="Pervasive.Data.SqlClient.4.0" name="Pervasive PSQL Provider v4.0" type="Pervasive.Data.SqlClient.PsqlFactory, Pervasive.Data.SqlClient, Version=4.0.0.0, Culture=neutral, PublicKeyToken=c84cd5c63851e072"></add>
<add description="Pervasive Provider, Release 4.2" invariant="Pervasive.Data.SqlClient.4.2" name="Pervasive PSQL Provider v4.2" type="Pervasive.Data.SqlClient.PsqlFactory, Pervasive.Data.SqlClient, Version=4.2.0.0, Culture=neutral, PublicKeyToken=c84cd5c63851e072"></add>
<add description="Pervasive Provider, Current Release 3.5" invariant="Pervasive.Data.SqlClient" name="Pervasive PSQL Provider" type="Pervasive.Data.SqlClient.PsqlFactory, Pervasive.Data.SqlClient, Version=3.5.0.0, Culture=neutral, PublicKeyToken=c84cd5c63851e072"/>
<add description="Pervasive Provider, Release 3.2" invariant="Pervasive.Data.SqlClient.3.2" name="Pervasive PSQL Provider v3.2" type="Pervasive.Data.SqlClient.PsqlFactory, Pervasive.Data.SqlClient, Version=3.2.0.0, Culture=neutral, PublicKeyToken=c84cd5c63851e072"/>
<add description="Pervasive Provider, Release 3.5" invariant="Pervasive.Data.SqlClient.3.5" name="Pervasive PSQL Provider v3.5" type="Pervasive.Data.SqlClient.PsqlFactory, Pervasive.Data.SqlClient, Version=3.5.0.0, Culture=neutral, PublicKeyToken=c84cd5c63851e072"/>
The two selections highlighted in yellow show the two duplicate entries. Note that they have the same invariant name. While deleting either <add> entry would resolve the issue for CONNECTION Client, this example shows that the second <add> entry already had another entry further down with the same type and version. These have been highlighted in green. Therefore the <add> entry with a description of "Pervasive Provider, Current Release 3.5" was selected for removal.
Anderssprachige Quellen
Englisch
TBD
