| Product(s): | Bentley MXROAD | ||
| Version(s): | MX XM and later | ||
| Area: | View Rotate 2D | ||
| Subarea: | |||
| Original Author: | Amita Shinde, Product Advantage Group |
To set the 'MX view rotate2D' as a function key on key board, following are the steps:
1. In the CAD menu go to "Workspace > Function Keys"
2. Select Key : F3
3. In the "Action" field type : mx view rotate2d
This should assign the F3 key to rotate the MX view.
