| Product(s): | InRoads | ||
| Version(s): | 08.11.09.493 | ||
| Area: | Profiles | ||
| Subarea: | |||
| Original Author: | Chris Key, Bentley Technical Support Group | ||
Where can you change the vertical exaggeration of a profile model in the SS3 OpenRoads product? There is not an option in any command settings to set this.
Once the Profile Model is created you can change the exaggeration of the view by clicking on the View Attributes > Civil > Exaggeration and set the value you wish to exaggerate the display for that particular view.
