Tangential Direction not reported in Geometry XML Report
Version(s):08.11.09+
Area: Analysis & Reporting
Problem:
I am in InRoads SS3.  When I attempt to create a Geometry XML Report, the Tangential Direction is not displayed in the report.
The first time you run a Geometry Report in SS3, you will need to verify that Format Options in the Bentley Civil Report Browser are set up correctly.  In the report browser, go to Tools > Format Options.  Make sure that the correct options are selected for Angular and Direction.
