| Version(s): | 08.11.09+ |
| Area: | Corridor Modeling |
| Original Author: | Kevin McDonald, Bentley Technical Support Group |
Problem:
Is there a way to disable automatic corridor processing in SS3? For example, every time we make a change to any part of a point control or parametric constraint, the entire corridor re-processes. How do we go about disabling this feature?
Yes, there are two locations to turn ON/OFF the automatic corridor processing.
1.) In the context menu as you hover over a corridor element, you can select the lock icon to Activate and Deactivate rules:
2.) In the Corridor Objects dialog, the same lock icon is available at the top of the dialog to Activate and Deactivate rules:
