Product(s): | InRoads, MX, GEOPAK |
Version(s): | 08.11.09+ |
Area: | Corridor Modeling |
Original Author: | Sanders Thomas, Bentley Technical Support Group |
Question:
When I want to create corridor, I receive a prompt to locate corridor baseline. What is a "corridor baseline"? In SS2 there is a separate menu called Modeler in the PowerCivil window, but now this menu is missing in SS3.
Answer:
The corridor baseline that you are prompted to select is the horizontal alignment; select the alignment from your graphics. Modeler > Roadway Designer has been replaced with the OpenRoads Corridor Modeling command.
There is a video available which demonstrates a workflow for creating a corridor using the OpenRoads tools. You may find this video helpful as an introduction to OpenRoads:
Video: Simple Workflow for Corridor Creation
