| Product(s): | InRoads | ||
| Area: | Evaluation | ||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
Why can I not locate the Tunnel Surface command within Tools, Application Add-ins?
The Tunnel Commands are only available in the Rail products (Rail Track Suite, Rail Track and Power Rail Track).
