| Product(s): | MX |
| Version(s): | 08.11.09+ |
| Area: | Data Import & Export |
| Original Author: | Jason Walsh, Bentley Technical Support Group |
Some user require the MX design model to be exported to a DTM file. The process below details the process for achieving this.
Create a Boundary around the Design Model (MX>Modify>Edit Strings>Create a Boundary around Model).
