Applies To | |||
Product(s): | InRoads | ||
Version(s): | 08.11.07.615 | ||
Area: | General | ||
Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
When launch Inroads 08.11.07.615es with MicroStation 08.11.09.459es, the program is freezes up and does not pass the initial window.
Select Start>All Programs>Bentley>InRoads Group (V8i SELECT Series 2)>Bentley License Tool. At the Activation Status tab, make note of your InRoads Product that has a Status of “Activated”. Select Start>All Programs>Bentley>InRoads Group (V8i SELECT Series 2) and selected the InRoads product that had an activated status.
