| Product(s): | InRoads |
| Version(s): | 08.11.07+, 08.11.09+ |
| Area: | Basic Settings |
Question:
Is there a way to automatically check InRoads files into ProjectWise when I exit the product?
Answer:
While you cannot "automatically" check in InRoads files, you can automatically enable the Local Document Organizer to be displayed upon exit. You will need to change a setting in ProjectWise Explorer:
